The brake lights work but only when I hit the pedal pretty hard and I have to press harder than under all normal braking situations to get them to come on.
I have the clevis and nut adjusted all the way to where they bottom out on the push rod. The brake light switch is also at the end of its adjustment.
What does the nut look like on the push rod? I was thinking maybe it should be a thin nut instead what appears to be a regular size nut. It appears that there is only maybe a 1/4-3/8" of adjustment even with no lock nut.
Is it possible there should be no lock nut? The AIM does show a lock nut.
Does the actual push rod screw into the booster further? Can I still adjust the clevis once everything is assembled by removing the clip and pin?
The booster, master cylinder, and brake pedal are all original to the car. All have been rebuilt including rebuilding the brake pedal and clutch pedal assemblies.
Obviously this is a safety concern. Brakes work fine with excellent feel just no brake lights under normal driving conditions.
Bill
Bill
