Ammeter Question - NCRS Discussion Boards
Ammeter Question
  • Clark K.
    • January 12, 2009
    • 536
    Ammeter Question
    My '65 L76 A/C Coupe has the factory ammeter. Since I am having to charge my battery after every drive, I suspect that my alternator is not putting out enough amps.
    When I am running my power windows or moving the headlight buckets, or I have the headlamps on, the ammeter shows a slight deflection into the negative range. The ammeter never shows a reading in the positive range. Does this reading on my car's ammeter indicate that my diagnosis is correct?
    If so, where do you recommend that I send my alternator in order to have it rebuilt to the exact factory specs?
    -Clark
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Ammeter Question
    Could very well be the regulator or wiring- a simple bad ground will cause the described problem.
    • Tom K.
      • February 26, 2008
      • 167
      Clark, I would start by checking the voltage with a digital voltmeter. With the engine running it should be 14.0-14.6 volts at the battery. Checking the voltage will eliminate the question of what the ammeter is showing. There is a possibility that you could have bad diodes in the alternator or as mentioned a defective voltage regulator.Hope this helps.
      Tom
      • William C.
        • May 31, 1975
        • 6037
        Amen to the post on Voltmeter check at the battery to verify the charging system. There are many posts in the archives regarding the ammeter system in the '63-67 Corvette and the fact that is not a direct reading system, and therefore unreliable for troubleshooting. Look at the charge across the battery terminals at about 2000 rpm and you will have your answer as to the alternator/regulator function with respect to the charge.
        Bill Clupper #618
        • Carl N.
          • April 30, 1984
          • 592
          Clark,
          Really sounds like you have an open ground. Check your glove box light, interior lights and so on.
          Also if you have a correct date coded alternator you may wish to consider a cheap rebuilt from Auto Zone - Advance Auto ect. You could install it and see if your problem goes away - same with battery - if it keeps draining down you will need to find the source of the drain. Put your date coded back and save it for judging.
          Carl
