OEM Spare Tire - NCRS Discussion Boards
OEM Spare Tire
  • Christopher K.
    • September 10, 2007
    • 311
    OEM Spare Tire
    I was doing some exhaust work today and decided to drop the spare on the '72....
    Sitting there was an original tire! No, it's not new. It probably ended up in there after the first new set of tires went on.
    Here's a few pics - I think the battery was fading on the 2nd shot.
    Chris
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
    • 6940
    Re: OEM Spare Tire
    Chris, One the original tire manufactuers was goodyear but in 72 its was not a radial tire, I am sure its a older tire but not the factory.There should be quite alot of details in the archives for 70/72 cars.
    • Reba W.
      • 932
      Re: OEM Spare Tire
      From the TM & JG
      [FONT='Shruti','sans-serif']Raised white letter tires were either Goodyear, Firestone and in 1972 only US Royal brand. The Goodyear tire had white letters reading Goodyear Wide Tread F70-15. [/FONT]
      • Christopher K.
        • 311
        Re: OEM Spare Tire
        Well of course you guys are exactly right - no radials in '72
        If I read the '73/'74 TIM correctly, this is one of the two tires possible for those years.
        Thanks for setting me straight,
        Chris
        Chris
          Re: OEM Spare Tire
          Chris
          Chris-----
          Yes, it might be a 1973 or 74 tire but it's definitely not one used earlier.
            • 15573
            Re: OEM Spare Tire
            Chris
            Chris,
            If you can find the indented manufacturer's code (probably on the inside, but maybe both sides) the last three numbers will be the date code in WWY format. for example 434 would be 43rd week of 1974.
            • William M.
              • July 31, 1993
              • 390
              Re: OEM Spare Tire
              Chris
              Missed by one year. That would be good for a '73.
              Bloomington Gold 2011
              Corvette Magazine 9/11
              Bloomington Gold 2013
              Corvette Magazine 3/13
              • Michael F.
                • 745
                Re: OEM Spare Tire
                when I bought a 70 few years back it had original spare it ( I verified it), anyway one day working in garage and heard loud bang/pop, checked around garage and found tire was shredded from a blowout .... fortunately the spare was not in carrier but just sitting against wall during car cleaning. glad I was not next to it.
                Michael
                70 Mulsanne Blue LT-1
                03 Electron Blue Z06
                • Jim S.
                  • March 1, 1986
                  • 1392
                  Re: OEM Spare Tire
                  Originally posted by Reba Whittington (8804)
                  From the TM & JG
                  [FONT='Shruti','sans-serif']Raised white letter tires were either Goodyear, Firestone and in 1972 only US Royal brand. The Goodyear tire had white letters reading Goodyear Wide Tread F70-15. [/font]
                  I always thought my spare in the 72 was an original. Didn't they use Firestones in 72 ?
                  JIm
                    • 6940
                    Re: OEM Spare Tire
                    JIm
                    Jim they did use Firestone in 72, flip the tire over and check the date as Terry says in his post.This will give you some sort of idea if its original.
                    • Jim S.
                      • March 1, 1986
                      • 1392
                      Re: OEM Spare Tire
                      [quote=Edward Johnson (49497);585285]Jim they did use Firestone in 72, flip the tire over and check the date as Terry says in his post.This will give you some sort of idea if its original.[/quot
                      Thanks Ed,
                      I will dig it out and look later.
                      I realize now that I read Reba's post incorrectly.
                      I see it says that they did use Firestones in 72. I read it at first to say " in 72 only US Royal . Meaning that was the only one used, not that it was only used in 72.
                      Sucks getting old !
                      Jim
