Where to send Balancer for Rebuild? - NCRS Discussion Boards
  • Christopher A.
    • February 13, 2009
    • 167
    Does anybody restore original Harmonic damners/balancers? My father has a 64 Corvette and it currently has a replacement balancer, but the timing marks do not line up correctly. I found his original balancer the other day and i would like to get it rebuilt if possible. The rubber ring is in pretty bad shape and will need to be replaced. This is for a 327/250hp, so there isnt much to the balancer overall.
  • Peter J.
    • September 30, 1994
    • 586
    Re: Where to send Balancer for Rebuild?
    These guys have done two for me and no issuesamper Dudes
    (800) 413-2673
    • Gary R.
      • April 1, 1989
      • 1796
      I sent out my 72's damper to Damper Doctor or someplace to that affect years ago in CA. I took pictures and witness marked it. When I got the damper back it wasn't mind, took 3 return shipments and several calls to get mine back. The ones send to me were not in as good of shape as mine was and even though I specifically asked for mine back it was just tossed in a core box when it arrived.
      • Harry S.
        • July 31, 2002
        • 5258
        Why don't the timing marks line up? I would think that if the one on the car is the same size as the original it should align. The KEY-WAY should be in the same spot. I say this assuming it's a 327/250 or 300 hp balancer.
        If what is there now is an 8 inch balancer then I understand the alignment problem. If it is an 8 inch balancer, then the timing chain cover has the timing tab in different place. You may need to get the correct timing chain cover.
        • Thomas H.
          • August 31, 2005
          • 1053
          I'd like to get the original one from my 60 redone and I have been holding back because of experiences like these.
          I suppose a call to the shop to inquire how to get mine back would be in order.
          Tom
          2007 Z06, Lemans Blue
          • Jaime M.
            • January 1, 2005
            • 32
            Chris
            The machine shop I'm having rebuild my engine is sending my original balancer to Damper Docker to rebuild. Their number is 530-246 2984.
            • Christopher A.
              • February 13, 2009
              • 167
              Thanks, i will call them in the morning.
              The balancer is aftermarket and that is why the marks do not line up. I put a bunch of aftermarket junk on his car 10 years ago and now i am putting it back to the way it should be.
              • Gary R.
                • April 1, 1989
                • 1796
                I just want to clarify that the work done on my original balancer was great. I installed it and checked it against TDC #1 and it was right on.
                I would recommend you just take the precaution and make arrangements that yours is what you get back.This would apply to any rebuilder you choose.
                The first one I got back was rebuilt but was also hammered on pretty good by someone and I knew it wasn't mine.
                • Domenic T.
                  • January 29, 2010
                  • 2452
                  Harry,
                  The outer part of the babancer with the marks slips on the rubber mount to another position.
                  I used to pin them before I got into restoring to prevent that.
                  DOM
