The bolt hole that receives the bolt that holds the long slender brace to the block is stripped out. I had to put a nut on th end of the bolt. What is the best way to fix this without purchasing a new generator? Can I purchase just the end plate?
Top generator bolt hole stripped out
Re: Top generator bolt hole stripped out
Joe,
You could look for a donor generator of the same vintage and swap the end cover, but I'd be tempted to try the helicoil first as Roger suggested.
If you have a local generater / alternator rebuilder, might be worth a phone call to them for suggestions also. I'm sure they have run across this in the past.
Tom1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
In Appreciation of John Hinckley- Top
The Helicoils work very well. If you run into a problem installing it you could also use a thread repair insert like these:
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
Erich- Top
