94 headlight rebuild - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    on my 94 daily driver after I turn off my headlights the doors go down fine but I can still hear the motor trying to move. I was told its the bushings going bad inside the motor. I would like to rebuild them. I see in Corvette Centrals catalog they list three different bushings
    1.http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
    2.
    3.
    So what one(s) do I need.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 94 headlight rebuild
    Keith, this is the one I would say you need. That's what we typically see.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Keith B.
      • March 7, 2008
      • 928
      Ok thanks. I don't understand how these will solve my problem. the motors work fine. but after the left one closes I can here it run. but I will order these and see what happens
      • John G.
        • January 1, 2006
        • 85
        Keith, you can trust Tom. I rebuilt my '93's motors with this kit. The "Delrin bushing" basically aligns the headlight gears. After time they just turn to powder as you will see when you open the housing. I suggest replacing in both headlights at same time.....it's a lot easier with the hood off. Good luck.
        John G.
        • Keith B.
          • March 7, 2008
          • 928
          since only the drivers side is giving me troubles I ordered a new gear and bushings for that and only bushings for the other side. it looks easy enough to repair
          • Bill H.
            • August 8, 2011
            • 439
