I am looking at a 1969 Corvette that appears to be well preserved but have questions regarding the radiator and hoses. I can read (see attachment) the upper hose p/n 3946852. According to the judging manual this is the hose for 350 with copper radiator and 350 4spd should have an aluminum radiator and 3935466 upper hose. Also the shrould (from the photo) does not appear to be metal per judging guide but the shroud looks fibreglass. Also, I can't tell from the photo, but if no overflow tank does that mean the radiator is probably copper and remainder of parts have been converted and no overflow tank is required? Except for judging and correctness, and it drives ok is there any risk to leaving as is?
I will be looking at this car later this week, so all I have are photos for now, What would be the correct p/n for the radiator, and will it be visible without removing anything?? Also, does the A.I.R pump look correct in the photo?
) so check for three matching hex heads. They might be hard to see given their location inside the shroud.
