63 340hp oil pan bolts - NCRS Discussion Boards
  • Alan B.
    • August 15, 2010
    • 15
    Hi, I'm putting together a 1963 340 hp.
    I understand that under 2 of the oil pan bolts there are little clips that hold the spark plug wires. I have all the bolts and the clips, I just don't know which bolts the clips go under. Any advise is appreciated. Thanks, AB
    • 6940
    Re: 63 340hp oil pan bolts
    Alan, The way I did it was to just lay the the U shaped sheilds where they normally go on the underside of block and that will give the placement of clips.
