I am in the process of restoring my '63 convertible, and need to remove a poorly repaired header panel/bonding strip from the car. Thus far I have been able to separate the rear most edge bonding strip from the hood surround (see crummy cell phone pics below), but I am trying to figure out how to access the sides and front edge. I can access the front edge behind the headlight buckets by removing the buckets, but I cannot access the middle section between the buckets.
Any advice you can provide would be great.
At this point all I can think of is to use a very long putty knife and go at it from the back side. Can't seem to find a putty knife that long though!
Mike
Front end was replaced in the mid seventies (last time the car ran) with a GM service hood surround. The hood surround was installed properly, but I removed the inner fenders to replace them with proper '63 versions. Next step is removing the header panel because I believe it is slightly bent and thus the nose isn't as straight as it should be.
Mike
