Source for Engine Broadcast Code Sticker? - NCRS Discussion Boards
  • Scott K.
    • September 30, 2010
    • 85
    Looking for the Engine Code broadcast decal that goes on the RH (passenger side) valve cover for a 1972 Corvette 350/200 with Auto Transmission, non EEC. Believe this is a CKX code. I've searched all the usual suspects on-line and interestingly, most stop around 1969 with no letters for the 70, 71 or 72 model year(s).
    Does anyone have a referral to a company that makes these or is anyone here perhaps making their own version on heat resistant adhesive paper? Should be the yellow sticker with black letters C K X (small block 350/200)
    Also looking for a replacement "Engine Starting Procedure" sticker for the LH visor for the same 1972.
    Thanks -
  • Gerard Q.
    • February 1, 2000
    • 284
    Re: Source for Engine Broadcast Code Sticker?
    I don't know if he's still doing them but I received mine from Patrick Hulst.
    • Kurt G.
      • April 30, 2005
      • 343
      Scott,
      Don't know that anyone reproduces the sticker, but you can make them yourself. I did. I used a thin, cheap manila folder that I got at Office Depot, cut it so it would fit into my printer and used a bold Aerial black font with 42 size. Worked great and passed judging in TX.
      Kurt Geis
      Chairman, Midway USA Chapter
      Targa Blue 1972, Top Flight and Duntov Award, 2014
      Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
      Arctic White 2013 60th Anniv Special Edition Conv.
        • 11608
        I think he is.
        • Kurt G.
          • April 30, 2005
          • 343
          Disregard my previous post. I finally found my stuff on the broadcast code labels. The correct font is Franklin Gothic Demi Cond, size 72 bold. The label can then be stuck on using Scotch double sided transparent tape. Sorry for the confusion.
          Kurt Geis
          • Kenneth H.
            • October 27, 2008
            • 500
            Scott,
            Check out the thread below.
            https://www.forums.ncrs.org/showthread.php?t=65323
            Thanks.
