Re: Grooved Cam for 65-66 425hp Big Block
Joe,
I appreciate the second opine on this, as there was a time as metallurgist, I was there checking tin on pistons, gears, cams, rocker arms, r/a nuts, studs, even the rod nuts we heat treated. Even when they tore out furnaces from the 30/40's to make way for nodular iron gear heat treating.
Joe,
the cam that GM sold over the counter for short track racing 340282 did not have the groove. the only cams i remember that were grooved was the 535 1st design L-88 and the 143 street cam you bought over the counter were grooved as long as i remember. the 362 street cams were not grooved which were the 143 replacement.
