I have a 1959 which was apparently hit in the left front side. I determined that the frame is bent slightly and I can't align the front end (camber on the right tire). Does anyone have or can tell me where I can get frame specifications or measurements. I have removed the body and have a frame specialist lined up to pick up my rolling chassis(?).
1959 frame specifications
Tags: None
- Top
Re: 1959 frame specifications
Chuck, '58 frame specs om a previous post. Gary....
https://www.forums.ncrs.org/attachme...3&d=1239664143NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
THE ATTACHED LINK MAY BE OF INTEREST OR HELP WITH THE ALIGNMENT
http://www.vetteweb.com/tech/vemp_0206_aligning_solid_axle_chevrolet_corvette/index.html- Top
THANK YOU !! You guys are great. The specs are just what I needed and the article explaining the process was terrifc. What a wonderful resource (NCRS and Technical Board) is. I would have never found that article on my own. Thank again for the help.- Top
Replaced left front frame horn to ST-12 frame specs on 62 vette....body man double checked chassis for squareness B4 proceding...attached is his sketch and dimensions...hope it helps someone here.Attached Files- Top
