54 wiring question (again) - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    The S terminal on the light switch shows two connections, one 16 gage from the brake switch and another with two wires on one connector, Is it intended that these two connectors occupy the same S terminal. The plan doesnt show anything on the D terminal. Thanks again for all your help!!!
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 wiring question (again)
    The brake light switch by the pedal has two wires going to it
    one is orange - the other I will have to look
    On the headlight switch - the dimmer teminal has 3 wires attached to it
    One for the radio
    one for the harness - rest of the gauges
    One for the cigar lighter
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 499
      Thanks Chris, it seems the S and D terminals work as one, clearly the plan shows the orange brake lead at the S term. But the other orange wire connector has two wires attatched to it. It doesnt seem two connectors should reside on one terminal. Why not put the brake wire on the D term? looks like they both operate as one.
      • Chris S.
        • January 1, 2000
        • 1064
        I have orange from the harness and orange to the brake light switch on one terminal - "s"
        I have nothing on "d"
        the dimmer teminal has 3 wires attached to it - the very first terminal towards the knob - same side as the orange
        One for the radio
        one gray 14 ga for the harness - rest of the gauges
        • Guy M.
          • November 1, 1993
          • 499
          Thanks Chriss, this has been very helpful, I appreciate the help
          • Chris S.
            • January 1, 2000
            • 1064
            no problem
            I just finished wiring my dash on 3803
            and doing electrical checks
            so I am very intimate with the underside of my dash.....
