67 Fueltank - NCRS Discussion Boards
67 Fueltank
  • Bill H.
    • August 8, 2011
    • 439
    67 Fueltank
    Hi Guys, What are you doing to restore the outside of an origional tank?
    The "tank paint" that has zinc in it?
    I would think that having it replated would be almos as much as buying a repo.
    I do want to keep this tank, the inside is like brand new. I was really supprised when I pulled the pickup/strainer, it looks like it just came out of a box.
    The last time there was fuel in the tank was 1979 and the little bit that was still in there washed right out.
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 67 Fueltank
    Looks like it is pretty good shape. Personally, I would just leave it alone and call it "patina". I definetely would not use the tank paint - trust me, it will look painted. If you want it to appear as new, then I would just replace it with a repro.
    • Stephen L.
      • May 31, 1984
      • 3148
      Re: 67 Fueltank
      I cleaned up my tank using purple power and then lightly cleaning using steel wool. Came out looking great. I then put on a light coat of satin clear to keep it clean.
      Here is a thread on the subject.
      https://www.forums.ncrs.org/showthread.php?t=80580
      • Bill H.
        • August 8, 2011
        • 439
        Re: 67 Fueltank
        Thanks Stephen, your tank looks great.
        SG's taking some of the dirt off but isn't working that well. I'll hit NAPA for some power purple.
