68 Rochester 7028219 Q-jet - NCRS Discussion Boards
  • Jeff P.
    • October 21, 2011
    • 287
    Looking for one of these impossible to find carburators. Any information on the where abouts would be Greatly appreciated. Whats on your shelf ???
  • Joseph K.
    • August 26, 2008
    • 407
    Re: 68 Rochester 7028219 Q-jet
    Jeff,
    You will need the date code also if you are going to have the car judged. I think that you need to be in that three month window before the car was made. There are carbs out there, and there are several carb dealers out there. The one I have worked with is in Middlesex, NJ. 732-356-433. be careful not to purchase a service replacement. The service replacement has a rectangular protrusion in the front of the carb.
    Good luck with your search. Joe
    • Jeff P.
      • October 21, 2011
      • 287
      joseph went to call but noticed u left out a number, guess this tip will cost 10 phone calls possiblily, thank goodness for unlimited long distance calls...lol thanks for the tip.
      • Jeff P.
        • October 21, 2011
        • 287
        Rectanglular protrusion ??? Where and what do you mean?? I see the fuel filter area. Could you share more information .
        • Jeff P.
          • October 21, 2011
          • 287
          • Jeff P.
            • October 21, 2011
            • 287
            • Michael W.
              • April 1, 1997
              • 4290
              Good old Google
              • Joseph K.
                • August 26, 2008
                • 407
                Originally posted by Jeff Piekutowski (53984)
                the one in you picture is not a service replacement.$(KGrHqIOKk!E58LD+sqzBOgK+!BNbQ~~60_3[1].jpg
                this one is a service replacement notice the protrusion on the left front(driverside) it sisort of rectangular not square.
                • Jeff P.
                  • October 21, 2011
                  • 287
                  joe
                  i see the protrusion in the photo and never seen one like that and know that mine don't have that feature either. Thanks for posting the impostor. The colors on this carb that i posted don't equal a 100% correct NCRS score do they ?
                  • Joseph K.
                    • August 26, 2008
                    • 407
                    You might get a point or two off for color but if the numbers are good and the date is within the allowable window before the car was made you should do well.
                    • Jeff P.
                      • October 21, 2011
                      • 287
                      Thanks for all the member posts.
                      • Jeff P.
                        • October 21, 2011
                        • 287
                        This is impossible to find just a swap meet parts carb 7028219...
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          Originally posted by Joseph Koehler (49378)
                          the one in you picture is not a service replacement.[ATTACH]36022[/ATTACH]
                          that is the holder and locator for different external carb solenoids used for idle speed when the A/C is turned on for example.
                          • Jeff P.
                            • October 21, 2011
                            • 287
                            Clem,
                            What your saying is that, that carb is for automatic transmissions?
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              Clem,
                              no i was referring to the projection on the top of the carb on the throttle side and what is it purpose
