54 exhaust pipe not quite right - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Not able to utilze my exhaust bracket that bolts to the tranny because the pipe isnt bent exactly correct. Anybody else expierience this??
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 exhaust pipe not quite right
    Yep
    put the exhaust in the bracket first
    then tighten up to the exhaust manifold
    the CC repro exhaust is not quite right
    you can also lengthen the slot to try to gain some adjustment.
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Lynn L.
      1953-55 Team Leader
      • February 1, 2000
      • 162
      I attached exhaust to manifold, place wood spacers to ctr exhaust in frame holes, then used a 2x4 to "factory bend" exhaust to fit trans exhaust clamp. I wanted to be sure exhaust seated well to exhaust manifold (no leaks) Watch crossover clearance under oil pan. Worked well.
      • John L.
        • February 1, 2005
        • 207
        Interesting - seems the "work around" is no real issue but I guess I should ask this question since I planned on placing an order for my exhaust system in January with CC ..... Is there another supplier that members have had better luck with? Certainly I would think there would be one supplier that makes their system available to several major parts catalogs so the little problem here may possibly be found from another company as well.
        Just wanted to ask - unfortunatly no exhaust on my car when I got it otherwise I may have had the local bend shop fabricate one for me...
        John Lannning
        • Guy M.
          • November 1, 1993
          • 499
          I had a hard time just connecting the pip to the manifold and Im not taking it loose, it doesnt leak now so Ill try the 2 X4 factory bend, I really want to use that clamp. Thanks for the input. My body is going on in May.
          • Chris S.
            • January 1, 2000
            • 1064
            I put the pipe in the exhaust hanger - loose
            then tighten up to the manifold.
            the RH pipe from C Central fits like crap
            it is real close to the pan
            with some work with the hanger on the trans side
            you can get it to fit pretty well.
            • Guy M.
              • November 1, 1993
              • 499
              It was all I could do to get it to bolt up loose but when it warms up a bit Ill try again to use the hanger
              • Gary H.
                • June 30, 1980
                • 155
                Is the trans bracket a repro? If it is there is part of your problem. I had a repro and it was not even close to fitting, so I made my own. Anyone interested in a repro trans bracket, CHEAP?
                • Guy M.
                  • November 1, 1993
                  • 499
                  Mines original, just a poor fitting pipe. I dont want to lossen it at the manifold now that thats right, Ill just try to bend it to fit the bracket.
