1966 Clock Removal - NCRS Discussion Boards
1966 Clock Removal
  • Timothy B.
    • August 4, 2008
    • 44
    1966 Clock Removal
    What is the best way to remove my time clock?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1966 Clock Removal
    remove the glove box door assembly, reach around back side of clock and remove the pair of dash lights and the power feed to the clock and the ground wire on the clock, then depress the V-shaped clips(there are a pair of them) , and while depressed, slip them away from the pair of posts on the back of the clock. good luck.mike
    • Timothy B.
      • August 4, 2008
      • 44
      Thank you Mike
      • Roger P.
        • February 25, 2009
        • 354
        Tim,
        I was able to remove my clock without removing the glove box door assembly. If you remove the two radio access panels on each side of the dash console, you will be able to reach in and slip off the clips. It's a little tight in there, but I have done it a few times without any issues. It takes me about 10 minutes in and out.
        Roger (50141)
