Wnen the new C2 rolled off the ass line what color was the undercarriage painted? Was it in a flat base paint or a satin base paint?
63 undercarriage
Re: 63 undercarriage
You'll get varied opinions as the sheen did vary. I believe somewhere.....between flat and satin is the answer. Mine is finished with a satin sheen.- Top
Mike, all of the suspension finishes are covered in the 63 Judging Guide, but here are a few guidelines for the major stuff:
frame: gloss to flat black (frames started out gloss black, but sat outside the plant for varying amounts of time, this altered the gloss significantly)
front stab bar: semi-gloss black or bare steel
Front control arms: Gloss black
steering linkage: bare
Front knuckles: bare
front spring: bare
shocks: gloss black
entire rear suspension (except spring): satin black (the judging guide says this is OK, but recommends other finishes. In reality all rear suspension components except the spring were black when they left St Louis)
rear spring: light grey
Hope this helps
- Top
- Top
Thanks John, you're not going to believe how hard it was to get the old paint off of my linkage, now you tell me I could have used a spray bomb
- Top
- Top
- Top
Michael,
As I recall from somewhere, the orders to the fellow that painted the chassis blackout was: "Paint everything black that isn't already painted"
Is that correct? Was it you or Dave that interviewed that fellow?
JR- Top
Michael, until the latest JG revisions come out, I think the JG still says front spindles should be bare. I got hit for having black overspray on them at Nationals, so I'm sure black ones will get a deduction, even though they may have ben that way coming our of St Louis
- Top
