63 undercarriage - NCRS Discussion Boards
63 undercarriage
  • Mike S.
    • August 21, 2011
    • 57
    63 undercarriage
    Wnen the new C2 rolled off the ass line what color was the undercarriage painted? Was it in a flat base paint or a satin base paint?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 63 undercarriage
    You'll get varied opinions as the sheen did vary. I believe somewhere.....between flat and satin is the answer. Mine is finished with a satin sheen.
    • Mike S.
      • August 21, 2011
      • 57
      Thanks, I will go with that. Mike
      • Stuart F.
        • August 31, 1996
        • 4676
        When you speak of "undercarriage" are you just referring to the frame and suspension? or are you including the floor pan (body(/
        Reason I ask is that my 63 underbody is unpainted fiberglass.
        Stu Fox
        • Mike S.
          • August 21, 2011
          • 57
          Sorry, should have been more clear. I mean the susspension. Mike
          • Michael G.
            • November 12, 2008
            • 2155
            Mike, all of the suspension finishes are covered in the 63 Judging Guide, but here are a few guidelines for the major stuff:
            frame: gloss to flat black (frames started out gloss black, but sat outside the plant for varying amounts of time, this altered the gloss significantly)
            front stab bar: semi-gloss black or bare steel
            Front control arms: Gloss black
            steering linkage: bare
            Front knuckles: bare
            front spring: bare
            shocks: gloss black
            entire rear suspension (except spring): satin black (the judging guide says this is OK, but recommends other finishes. In reality all rear suspension components except the spring were black when they left St Louis)
            rear spring: light grey
            Hope this helps
            • Mike S.
              • August 21, 2011
              • 57
              That really helps, will print off the judging guide, never thought to do that. Mike
                Mike -
                I know what the JG says, but it's wrong. The steering linkage was painted chassis black as an assembly just before it was shipped from Buffalo.
                • Michael G.
                  • November 12, 2008
                  • 2155
                  Thanks John, you're not going to believe how hard it was to get the old paint off of my linkage, now you tell me I could have used a spray bomb
                  • Mike S.
                    • August 21, 2011
                    • 57
                    Thanks for the info, hope mine is ready to judge maybe this summer. Lot of things wrong when i purchased in July. Mike
                    • Rich C.
                      • January 1, 1994
                      • 383
                      Mike -
                      Did that continue to ....say.... '73?
                      '73 LS-4 454 owned 21 1/2 years
                        Rich -
                        I left St. Louis in early '68 - don't know what the process was after that; check with the C3 guys.
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          Michael,
                          I think the front spindles are coated with chassis black along with the entire knuckle and brake assembly.
                          • Joe R.
                            • July 31, 1976
                            • 4547
                            Originally posted by Michael Hanson (4067)
                            Michael,
                            Michael,
                            As I recall from somewhere, the orders to the fellow that painted the chassis blackout was: "Paint everything black that isn't already painted"
                            Is that correct? Was it you or Dave that interviewed that fellow?
                            JR
                            • Michael G.
                              • November 12, 2008
                              • 2155
                              Michael, until the latest JG revisions come out, I think the JG still says front spindles should be bare. I got hit for having black overspray on them at Nationals, so I'm sure black ones will get a deduction, even though they may have ben that way coming our of St Louis.
