Mid Year hood seals - NCRS Discussion Boards
Mid Year hood seals
  • Ronald L.
    • October 18, 2009
    • 3248
    Mid Year hood seals
    Were any of the mid year hood seals "secured" at the ends with a pin into the fiber glass?
    I'll get a picture ...
  • Keith G.
    • October 31, 2006
    • 316
    Re: Mid Year hood seals
    1967s had the pins.
    • Gene M.
      • April 1, 1985
      • 4232
      Originally posted by Keith Geppert (46462)
      1967s had the pins.
      none on the AO Smiths body
      • Keith G.
        • October 31, 2006
        • 316
        Thanks Gene, I was just getting ready to put pins in my AO Smith car, I got docked at a chapter meet in Minn. for not having them. The JG does not say anything about AO Smith cars. I drug my feet a little in Minn but got out voted.
        • Brian M.
          • February 1, 1997
          • 1837
          I'm with Gene.
          • Page C.
            • February 1, 1979
            • 802
            I,m with Gene. Hopefully we can get this in the new 1967 JG as a St. Louis only item.
            Page Campbell
            • Ronald L.
              • October 18, 2009
              • 3248
              Did it start on Job 1 1967?
              • Wayne W.
                • April 30, 1982
                • 3605
                Heres a picture, but I have never been able to determine whether they were AOS, ST.Louis specific or not. Hoods can be changed. Obviously this is a St. Louis.
                • Tom D.
                  • September 30, 1981
                  • 2126
                  See two more corners from an original St. Louis Hood.
                  https://www.forums.ncrs.org/showthre...25037#poststop
                  Body number is on the Tag.
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                  • Tom D.
                    • 2126
                    Trim Plate Tag 1967 St. Louis 390 HP Coupe. No hood swap on this car.
                    Michigan Chapter
                    Tom Dingman
                    • Tom D.
                      • 2126
                      '67 pin hole location. Same hood as above.
                      Michigan Chapter
                      Tom Dingman
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        Another thing that gives this away as a St Louis hood is the no paint ring where the hood pin screws in. AO Smith hoods this is all painted as pins installed after black paint.
                        • Gene M.
                          • April 1, 1985
                          • 4232
                          Just for general information not all St Louis hoods got the hole drilled and pins installed. I've come across quite a few without them.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            Do we have any very late 66 and or very early 67 examples to know when this started?
                            • Scott S.
                              • September 11, 2009
                              • 1961
                              Is this hood weatherstrip push-in rivet the same as the metal ones used on the "L" shaped door weatherstrip for 1966-67?
                              That would make sense since they were on hand, but the example in Wayne's photo above looks larger than the door weatherstrip push-in rivets.
