Working on bringing some of the parts and numbers on my 1972 into closer alignment with the findings from a recent flight judging. One of the things we identified is that the carb on the car was not the technical correct one so I located and purchased the correct one.
Interested in advice, tips and information on the correct process to swap this out. Sure.. I could pay the local shop to do it... but with the wealth of knowledge here and a little hands-on, perhaps I'm underestimating what appears to be a straightforward swap. That said, I'd like to give it a shot.
The engine is a 1972 350/200hp (non LT-1). Car has automatic trans and air.
Carb that's on there now is a 17054931. One I purchased is a 7042202 A2 DJ.
Carb has been fully rebuilt, tested and tuned to exact factory specifications by the shop I purchased it from.
Here's the new Carb:
Here's what's there right now...
In looking at my current set-up, would the process be to:
1. Remove linkage / connections from LH side
2. Carefully disconnect fuel line and vacuum connections from FRONT.
3. Disconnect connections and vacuum connections from RH side.
4. Disconnect brake booster connection from REAR.
5. Unbolt carb from manifold
6. Remove center stud
7. Remove Carb
8. Remove old gasket
9. Place new (gray colored) gasket
10. Set carb and lightly apply nuts
11. Attach gas line FRONT
12. Attach power brake line REAR
13. Use X pattern to tighten bolts slightly above hand-tight.
14. Connect vacuum hoses.
Is this pretty much it?
Questions:
- Any other material or sealant used between gasket & carb?
- Should I be changing the studs and nuts at this time too?
- How much gas is going to come of that fuel line?
(just have a rag handy?)
- Do I need to use any teflon tape on the brake fitting to carb?
Once I get the basic swap done, then we'll go for setting up the Idle Stop (which was missing on current vehicle and then the TSC on the RH side. I've bought ALL the right original parts.. but first things first.). Also, I have the evap hose an T for the PCV on order.. I know that is not correct as is. Right now, focusing on the carb swap.
Looking forward to hearing the group input on this.
7. Remove Carb
Questions:
