Changing the brake lines(top on frame)1964 coupe - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    I am going to change all the brake lines and all the clips on my 64 coupe
    The front to rear brake line sits on top of the frame(with clips and screws)which i hope is not to difficult to access?
    I am bit worried about that the brake line is on top of the frame will be difficult to change since it is on the top on the frame on the drivers side.
    I hope that there will be no problem doing this without having to lift the left side of the body off the frame a little?
    There is\was no rust(not even surface rust)on the frame before i spray painted the undercarriage
    Any good advices on how i should do the brake line work? I sure will need them
    The car that is going to get new brake lines
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Changing the brake lines(top on frame)1964 coupe
    I did the brake lines on my 63 and I could find no way to replace the line you describe without lifting the body. I ended up exposing some of the line at the rear cross member. I had to cut and splice the line at that location. The way I installed it I will be able to tuck it on the frame if I ever decide to lift the body.
    • Claus S.
      • December 30, 2010
      • 414
      That is exact what i am afraid of
