Wobbly pulley Water pump bearing - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
    I head a noise coming from what I thought sounded like the water pump. I shut the car off and it seems that the top pulley has a wobble in it. The bolts holding it on are tight, is this a bearing going out in the water pump shaft? the pulley has a lot of slack in it, when I grab the fan at work it back and forth.
    Re: Wobbly pulley Water pump bearing
    Lyndon------
    Most likely, the waterpump bearing is shot. You'll need to remove the fan, fan clutch and waterpump. If it's an original pump, you'll probably want to have it rebuilt.
