I've posted many times regarding my recurring Holley fuel line leaks. As a quick review my car is originally a 435 but until I get the tri power rebuilt I've been running a '71 LS6 intake with LS6 fuel lines and an aftermarket Holley Street Avenger carb. I can't get it to stop leaking at the carb usually between the inlet and the line itself. I've replaced all the fuel lines/block with new ones from Inline Tube (twice!) and even put new inlets on the carb which was new. Anyway, reason for this post is it appears that when the car sits for a while a leak develops. I had it not leaking and then the car sat for a few weeks, started it last night and gas seeping from both lines at the carb! Someone told me to put teflon tape on the threads and even though I know I shouldn't need it I'm wondering if that might help - maybe the lines are coming lose.
About ready to go ahead and rebuilt that tri-power but then I'll have even more potential for leaks. Could that Street Avenger carb be the issue some how?
