I need to replace the headlight switch (or see what issue is once I remove it, possibly rheostat cleaning as interior light dimmer quit working). Question, do I need to remove the steering column to give room for left lower dash removal? I read some Wilcox documentation that states when the steering column is lowered but not removed, the lower dash pad will sit on the column and distort the area around the lower collar. Wilcox also states that people that attempt to replace the headlight switch w/o taking out the lower dash pad will almost 100% of the time break the sub-straight of the dash pad between the speedo and tach.
How difficult is it to remove the steering column?
Thanks!
Thanks!
