In 1964, what is the difference between the J56 and J65 brake options? Thanks....
					1964 Brake Option
Re: 1964 Brake Option
Larry -
About $580.00
The short version is:
J65 was sintered metallic linings on the shoes, with finned drums.
J56 was a different type of metallic lining (Ceremetallix) on special shoes, with special ventilated finned drums, internal fans, ventilated heavy-duty backing plates, front backing plate air scoops, dual-outlet master cylinder, and vacuum booster; essentially the same brake system as the '63 Z06.
Others will add more gory detail.
						- Top
Larry,
I'm sure John meant to say J65 was sintered metallic linings on the shoes, without finned drums. Drums for J65 looked exactly the same as standard drums.
Only the Z06/J56 package drums had fins.- Top
Here's the NOS J65 front shoes and interesting installation instructions on how to prepare the standard finish drums for use with the metallics.
y- Top
Michael -
Yup, fat-finger typo, and I can't edit it any more. The J65 drum (non-finned) was the same raw casting as the base drum, with a finer micro-finish on the friction surface.- Top
- Top
- Top
My 64 J65 front drums have an 'X' and an 'R' stamped into the web piece. Also had a green brush mark, and a white brush mark on them. The rear only had an 'L' stamped into the web. All 64's with J65 had a booster as standard. My old 63 J65 front pull back springs were thicker than standard pull back springs, had a purple/reddish color.
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Is there a spec on this ? Just measured one of the two Jan-Feb '64 rear drums I have [cast on edge W8____ 3828688] and get 0.108" thick on the web [assuming the web is the disc with the 5 wheel studs and the big center hole for the hub of the spindle].
Part of a complete rear suspension assy I bought years ago, just to get the pumpkin. They have regular linings but I don't know the past history -- was a 4.56 car so anything is possible
						- Top
Wayne,
Yes, the web is the disc section of the drum that looks like a dinner plate. Measure the thickness between the 5 holes for the wheel studs.
Engineering specs for the standard drum call for .109-.119". Drum web for metallic brakes is .125-.135".
I should have mentioned that the different web thickness for metallic drums is only for front drums. The rear drum web thickness is the same for both standard and metallic shoes.- Top
