Hi; I'm having a problem with the low beam headlight on my 67. The passenger side light is out when on low beam, but all four light up when the high beams are on. I've replaced the light and it didn't help. So, it seems to me that fuse, bulb, ground and wiring are okay. Does anyone have an idea for me to try? Thanks for any help.....
Headlight problem
Re: Headlight problem
Greoge, the low and high beams on the drivers side have wires that feed the pass side headlamps low and high. check the wires on the driver light.Maybe a broken wire.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
