In checking the archives on the subject of Steering Box Finishes, they speak almost entirely to C-2 applications. I am after several C-2 projects taking on a C-3 (1970). In reading the 70-72 JM, it indicates "Steering gear box was natural finish on earlier cars and semi-gloss black on later. 1970 often had two yellow paint inspection marks".
My questions actually could apply to C-2 or C-3. Would the "natural", actually be "as cast", which if like many other cast parts, would have a black preservative (settles primarily in the low spots and rub off the high spots) that would resist rust for a short time. If so, would the black mentioned in the JM, actually be the preservative (as cast) rather than an actual paint.
Then this leads to the question of the inspection paint daubs. I believe these would be final inspection indicators (typically yellow) just before the unit left Saginaw. I find it hard to believe, as many might, that Saginaw would do the inspecting process, then send the unit back for paint (black); therefore, the belief of the daubs under the black paint-just would not have happened, in my opinion.
My belief is the boxes were "as cast" and had varying amounts of the black preservative. Further my belief is both: C-2 & C-3 boxes would have been delivered to the assembly plant and appeared black (as cast), with inspection daubs visible. Then it would have been totally possible in the "black out" process, for black out black paint to have been over-sprayed on to the top portion of the box, which may have been sufficient to cover the inspection daubs, and therefore confirming many of the threads that black appeared primarily on the top portion.
Any thoughts are appreciated before I finish my box.
Mike Zamora
#12455
Mike Zamora
#12455
