My new windshield was finally installed yesterday. As an aside, if you are replacing a windshield use only Paragon clips. We had to install and remove the new windshield twice because I originally bought non-Paragon clips. The lower molding could not be instrted into the clips.
The outer moldings were installed with the windshield. The interrior upper and lower are back on. My questions involves the interrior side (vertical) garnish moldings. At the upper corner, do the inside moldings get fitted under the outside molding or on top of them? It seems that the inner moldings should be under the outers at the top corner but I can't seem to get them inserted.
Thanks for any advice or even a photo.
Happy holidays to all.
Doug
Doug
. It was east Texas, after all).
). Also, if I'm reading it correctly, this agrees with '65 AIM UPC 1, sheet F22, View A.
