54 shifter spacer? - NCRS Discussion Boards
54 shifter spacer?
  • Guy M.
    • November 1, 1993
    • 499
    54 shifter spacer?
    Is there supposed to be a spacer behind the chrome shifter bell??? Thanks as always
  • Troy P.
    • February 1, 1989
    • 1279
    Re: 54 shifter spacer?
    You mean a washer just under the bell?
    • Guy M.
      • November 1, 1993
      • 499
      Well, Mary Joe has a "spacer" for sell but in nolands book I dont see it. Hers looks to be about 1/8" thick with the same bolt pattern. Im confused as if there is this thing under there or just a washer under the bell. Im putting the shifter together and have the "specill washer" for the spring but Im not sure if there is another "special washer under the bell. I believe I have everything for the shifter assembly but this spacer deal has me confused. Im also trying to figure out the mounting bolts, looks like tapered screws, not sure of the size. Thanks Troy, I appreciate it
      • Troy P.
        • February 1, 1989
        • 1279
        There is a chrome plate that goes on top of the carpet and the edge of the bell fits inside of a lip on this ring. If you provide me your fax number I can fax you an exploded view of the entire shifter machanism from acorn nut to cotter pin at the tranny.
        • Guy M.
          • November 1, 1993
          • 499
          Wow, that would be great......303-271-8282........my work fax, ill get it Wednesday. Thanks a bunch Troy!
          • Troy P.
            • February 1, 1989
            • 1279
            Will do it tomorrow.
            • Chris S.
              • January 1, 2000
              • 1064
              Troy - is it emailable?
              If so - send me a copy for my records.
              Chris
              1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
              Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
              1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
              1957 Corvette - FI 3 sp - Black and Silver
              • Troy P.
                • February 1, 1989
                • 1279
                I have a hard copy Chris and don't want to bother with the scanner. I'd be please to fax it though.
