Starting instruction label sleeve - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
    Did the cars from the 70-72 have a Starting instruction label sleeve on the drivers side visor?
    • 3415
    Re: Starting instruction label sleeve
    Hi Lyndon,
    The 70-72 Judging Guide indicates that the starting label was on 72 model year car's sun visors. I don't believe they appeared on any 71 cars.
    • Reba W.
      • 932
      There was no paper sleeve for 1970-72 visors. The cloth label that began around December 1971 had adhesive backing.
      • Lyndon S.
        • April 30, 1988
        • 1027
        The ones showing the ignition key and such is for earlier cars?
          • 6940
          Lyndon, I got a repro one for my 72 that looked as the original and correct part no. go to Jim Osbornes reproductions Web site. If I remember correctly there were a few different part no.s It maybe spelled out in the JM. ( Early and Late). Also they don't like sticking to the comfort weave visors, it is a peel and stick, you might want to very lightly spray some extra adhesive, be careful it is a cloth material and to much extra glue will soak through.
          • Erik S.
            • January 1, 2005
            • 407
            for illustration purposes a picture of a very original 72 that we flight judged 2 years ago: sorry bit out of focus pic though
            • Lyndon S.
              • April 30, 1988
              • 1027
              So I am trying to get this right for 1971 cars there was no starting label? 1972 cars had a label, as did the 68-70 cars? Is that right?
              I don’t understand why some years would have instructions then other years not, was the 71MY some other place?
              • Mike F.
                • April 25, 2011
                • 668
                Only 72's had the label.
                  • 15573
                  I don't know about 1968.
                  1969 had a starting instruction sleeve -- because the key moved from the dash to the steering column and someone thought owners needed to know where to put the key.
                  19760 & 1971 Owners were expected to read the Owner's Manual. Fancy that idea.
                  1972 starting instructions are on a glue on sleeve -- Lawyers.
                  You should see what you get with new cars, but it is best we don't go there. Ignorance IS bliss.
