C3 headlight Spring and other questions - NCRS Discussion Boards
  • Charles P.
    • April 30, 2005
    • 332
    Anyone who has ever worked on C3 headlights knows the biggest headache is the installation of the springs. I have had to remove them and install them by hand because I don't have a spring puller. If you have done, this what type and brand do you have? Which brand/style works best. Also there are teflon bushings that look like lima beans. Do the lips face the eye or do they face the outside where the cotter pin is.
  • Graeme B.
    • October 23, 2007
    • 213
    Re: C3 headlight Spring and other questions
    Hi Charles,
    I use pointy nose pliers and the lips go to the outside.
      • 3415
      Hi Charles,
      "Lima beans".... all along I've been thinking 'kidney beans'.
      And now I have to think of beans with lips!
      Happy New Year!
      • Robert S.
        • June 30, 2001
        • 230
        When I had to work on the headlights on my son's 74' I made a spring install/remove tool using a length of brazing wire which I bent into a small hook on one end and on the other end I drilled a small hole in a piece of half inch dowl stock, inserted the wire and bent it around the dowl stock. I think the wire was about 18 inches long.
