1960 Block - NCRS Discussion Boards
1960 Block
  • Al E.
    • September 5, 2011
    • 313
    1960 Block
    I have recovered a block from a guy who claims this block came with my car, which he removed in the 70's to rebuild, however there is not a VIN on the stamp pad only the Engine info.
    My car came off the line in Oct 1959 should it have a VIN on the block as well.
    • 6940
    Re: 1960 Block
    Al, I am not a expert C1 guy, But I believe the early 60 cars did not have the VIN stamped in the pad, post your VIN no. so some of the C1 guys can help you.
    • Joe R.
      • May 31, 2006
      • 1822
      Re: 1960 Block
      Al,
      I would recommend getting the Technical Information Manual and Judging Guide from the NCRS store. While you're waiting for it to arrive, post all the numbers on your block (casting numbers, casting date, etc). Or better yet, post pictures. Meanwhile, folks more knowledgeable on your year should chime in soon.
      Joe
      • Arland D.
        Moderator
        • July 31, 1980
        • 415
        Re: 1960 Block
        Al,
        There may be some newer guidelines, but a while back up to approximately VIN # 1800 no VIN - VIN # 1801 to approximately VIN # 5394 3/16" characters using no gang - approximately VIN # 5395 to end of production 5/32" characters held in a gang. Someone who is more current may correct these guidelines as necessary but it's a place to start.
        • Al E.
          • September 5, 2011
          • 313
          Re: 1960 Block
          Thanks a Million. I will do just that
          • Al E.
            • September 5, 2011
            • 313
            Re: 1960 Block
            thanks for the info. I am a rookie at this.
            • Jim D.
              • 2882
              Re: 1960 Block
              The latest car that I've documented without the VIN is #1135 and the earliest I've found with the VIN is #1322. :Let us know your VIN. I hope this helps.
              • John F.
                • March 23, 2008
                • 2395
                Re: 1960 Block
                Welcome aboard Al!
                • Al E.
                  • September 5, 2011
                  • 313
                  Re: 1960 Block
                  Thanks I am excited to be here.
                  • Al E.
                    • September 5, 2011
                    • 313
                    Re: 1960 Block
                    VIN # is 101173. I think the car was built in OCT or NOV. However the block was casted in July. I have pick up the block yet but its a Flint block with the 270hp
                    • Philip P.
                      • February 28, 2011
                      • 558
                      Re: 1960 Block
                      Al, that VIN would make it a Nov 59, maybe the first week, block according to NCRS Spec guide that I have.
                      Phil
                      • Al E.
                        • September 5, 2011
                        • 313
                        Re: 1960 Block
                        So now the question is.. did blocks for cars built in Nov 59 have the VIN stamped on them.
                        • Jim D.
                          • 2882
                          Re: 1960 Block
                          That falls into the "unknown" area I've established. Please post a pic. of the pad when you get the motor. It may help narrow that window a bit. What is the assembly date stamped on the block? A July casting in a Nov. car is very unusual.
                          • Dick W.
                            • 10483
                            Re: 1960 Block
                            Short answer for 1959......NO
                            Dick Whittington
                            • Jim D.
                              • 2882
                              Re: 1960 Block
                              Car #1135, built 10-30-59 did not have the VIN stamped on it. Car #1322, built 11-16-59 does.
