wiper motor rebuild - NCRS Discussion Boards
wiper motor rebuild
  • Lyndon S.
    • April 30, 1988
    • 1027
    wiper motor rebuild
    Need suggestions on someone to rebuild my windshield wiper motor.
    • 3415
    Re: wiper motor rebuild
    Hi Lyndon,
    I had 'Corvette Specialties of Maryland West' repair my wiper motor. I was pleased with the work!
    They advertise in the DRIVELINE.
      • 15573
      I know we have kicked this subject (although not specifically for 1970) recently. Might have been for 1968-1972 so search without a date. There were three or four potential sources listed.
      Work it babe!!
      • Mike F.
        • April 25, 2011
        • 668
        Here's where I had mine done. Great job. http://www.wiperworks.net/
        • Lyndon S.
          • April 30, 1988
          • 1027
          I do searches, but for what ever reason with this NEW FANGLED, **** they dont work for me
          • Larry M.
            • January 1, 1992
            • 2688
            Many folks HIGHLY RECOMMEND this guy. He is one of the folks listed in the thread that Terry M mentioned. http://www.restorationservice.net/
            Larry
            • Rick A.
              • July 31, 2002
              • 2147
              can recommend two different folks, depending on where you are in the country - Rick Stotler in Maryland and Joe Ray in Arkansas - both are reasonable in their pricing and very responsive - can provide contact info for either if you want
              Rick Aleshire
              2016 Ebony C7R Z06 "ROSA"
              • Lyndon S.
                • April 30, 1988
                • 1027
                on 1971 cars how many pumps do the wiper motors have? are they all 3 or 5 ports?
                • Bill L.
                  • February 1, 2004
                  • 1403
                  Rik's Restorations in Maryland did my 70. It was perfect. Great guy to talk to as well.
                  Bill
                    • 3415
                    Hi Lyndon,
                    The number of ports on the washer pumps was changing during the 1971 model year because of the earlier demise of the headlight washers; based on the use of the pumps on hand.
                    The TIM/JG indicates the the 5 port pump continued to at least serial numbers in the mid 12,000 range. Pumps after that would typically have 3 ports.
                    Also changing during that period, was the presence of the washer hoses in the vacuum hose bundle going to the headlights.
                    My mid- January built 71, #6589 has the 5 port pump, the washer hoses cut short, and the holes in the headlight bezels for the washer nozzles, but no nozzles. It has a short piece of washer hose running between 2 of the ports.
                    • Mark D.
                      • June 30, 1988
                      • 2142
                      This is the one Corvette Specialties of Maryland did for me. I was very happy with the results...
                      Kramden
                      • Rick A.
                        • July 31, 2002
                        • 2147
                        Rick Stotler (Rick's Resotrations) used to work for Corvette Specialties of Maryland and is Brian Tilles brother-in-law
                        Rick Aleshire
                        • Thomas H.
                          • August 31, 2005
                          • 1053
                          Hi Lyndon,
                          Interesting. My 71 SN 1632 has a 3 port pump and the hoses routed and laying under the wiper motor. The wiper motor is original to the car, possibly someone changed the outlet portion to a 3 port?
                          Tom
                          2007 Z06, Lemans Blue
                            • 15573
                            [QUOTE=Thomas Hoyer (44463);594689]Interesting. My 71 SN 1632 has a 3 port pump and the hoses routed and laying under the wiper motor. The wiper motor is original to the car, possibly someone changed the outlet portion to a 3 port?
                            Tom
                            How much of the headlamp washer system is on your Corvette Tom?
                            • Jerome P.
                              • October 22, 2006
                              • 607
                              Wiperworks did a great job on mine.
