1954 Brake Pedal Pad width - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    Hello -
    I wanted to verify if I have the correct service brake lever/pad on my 1954. The metal brake pedal arm has a plate for the rubber pad that is approximately 3-1/8" wide but the replacment rubber pedal pad I received from one of the parts supplyer is approximately 5" wide so I am wondering if I have the incorrect part or was the brake pedal changed on my care sometime down the line.....any thoughts?
    Much appreciated!
    John Lanning
  • Troy P.
    • February 1, 1989
    • 1279
    Re: 1954 Brake Pedal Pad width
    I ran into the same thing on a 53 I restored recently.
    • Jim L.
      • September 30, 1979
      • 1805
      The replacement pad sounds right to me. Here is the original brake pedal pad on my unrestored '54, #3300:
      Jim
      • John L.
        • February 1, 2005
        • 207
        Thanks for posting the photo...at some point in the past the car did have a 3 speed installed so more than likely the pedal arm is a retro-fit at that time from a 3 speed car or the pedal for some reason was shortened. question answered.
        Thanks!
        John lanning
        • Troy P.
          • February 1, 1989
          • 1279
          Same with 53 #125 that I worked on and my 55 as well. Both were 3 speed conversion cars. Then someone takes the clutch pedal out and leaves the smaller brake pedal behind.
