I've attached some pictures of my 68 frame after cutting away the rust damage to the driver side. The remainder of the frame appears to be very solid with surface rust only and not much pitting. I even removed the end cap on the passenger side frame rail so I could see if there was any hidden damage and it looks great. I'm having the frame blasted now, so I'll know for sure the condition in a few days. Assuming it comes back from the blaster in good shape, I'd like to repair this frame since it is original to the car. I don't want to replace the entire kickup assembly since without jigging it pretty securely, I think there would be a good chance of getting it installed incorrectly and also I would lose my VIN stamping. My thinking is that if I removed the kickup reinforcement and sectioned the lower half of the kickup in an area that was covered by the reinforcement, once the crossmember damage was repaired, a new kickup lower section piece was grafted in, a new reinforcement installed, and the frame rails repaired that I'd have a virtually undetectable and strong repair. The problem is that I cannot purchase only a lower half of the kickup. I can buy the entire kickup and cut it apart, but that seems to be an expensive and time consuming way to go. Any opinions or experience with this type of repair? Anyone have a driver side kickup section that they would be willing to sell?
Based on looking at the pictures that I've added to this post, Vette Products of Michigan tells me that this frame has holes in it for mounting a side exhaust, which should not be there on a 68. I don't know which holes they are talking about and if they could have been added at some point in the cars past. If they are not original, I would weld them shut. Can anyone help me identify the holes in the frame rail that should not be there?
On the #4 crossmember there are 2 small holes adjacent to where the spare tire carrier bolt attaches on both sides. (the picture only shows one side) There was nothing attached to the crossmember at these positions when I disassembled the car, so I'm not sure what their purpose is or was. Are they supposed to be there and if so, what is supposed to attach to them?
Thanks for all the help with my project.
John Brough
John Brough
