Should there be a Cam Thrust Plate on a 66 427??? - NCRS Discussion Boards
    Re: Should there be a Cam Thrust Plate on a 66 427???
    Originally posted by Clem Zahrobsky (45134)
    chevy 6 cylinder engines used gear drive cam with a thrust plate. check the part number and see if the 6 cylinder used the same thrust plate
    clem------
    From what I can tell, the 6 cylinder thrust plate was either GM #3707916 or 2454008. Unfortunately, I don't have the part number for the big block plate since I don't have HD truck parts info. However, based on the info you provided earlier in this thread, the big block thrust plate/bearing looks like it was GM #3864862.
    • Ray K.
      • July 31, 1985
      • 369
      All----
      The Heavy Duty truck 366 and 427 engines did indeed use a gear drive camshaft in those applications which required a thrust bearing. There is one camshaft listed for L-88 engines which was a gear drive cam -- part #3925533 and there is a notation in the H-D part catalog that it requires a thrust bearing #3887871
      Ray
      • Clem Z.
        • January 1, 2006
        • 9427
        #18
        a lot of performance parts are made from HD truck parts like the deep sump oil pan we discussed on this site before.
          #19
          Originally posted by Ray Kimminau (8917)
          All----
          Ray
          Ray-----
          The gear drive cam for L-88 was never used on a PRODUCTION engine. It was strictly a SERVICE-only piece.
          • Domenic T.
            • January 29, 2010
            • 2452
            #20
            For what it' worth. When I got my 67 443/427 it was bastardized with headers and a aftermarket gear drive that didn't have a thrust plate, only a teflon button to keep it from pounding the aluminum timing cover.
            When I took the engine apart the gear tore up the casting and I had to machine the block and make a thrust plate for the new cam (with a double roller chain) to fill the worn area.
            The gear set up is in a 454 now that is on the shelf. It does not have a thrust plate, only the teflon button.
            So if I understand things, I will need to add a thrust plate or just get rid of the gears?
            DOM
            • Clem Z.
              • January 1, 2006
              • 9427
              #21
              DOM
              straight cut gears put no reward thrust on the cam to wear the block but helical cut gear do so you need a thrust plate. the pressure that pulls the cam in to the block is caused by the valve spring pressure on the lifters so stock springs should not cause a problem. heavy springs like after market roller cam springs will cause the gear to wear in to the block because of the added pressure and you need a thrust plate
              • Domenic T.
                • January 29, 2010
                • 2452
                #22
                Clem,
                Thanks, the gears are the loud straight cut.
                You saved me some time, I was going to remove the gears.
                DOM
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  #23
                  Clem,
                  DOM
                  if this is the setup with the "dog bone" holding the 2 idler gears check it for cracks as i have seen some break in two. this too late for you but i always drill a .032/.040 hole thru the block thrust area into the oil passage to get more oil to the block/gear interface
