67 427 ignition top shield - NCRS Discussion Boards
  • Jeremy H.
    • January 1, 1999
    • 260
    Is there a difference between the 427 ignition top shield(large piece around distributor and coil) for the 4bbl vs tri-power engine options? I've looked at a lot of the suppliers pictures and can't seem to tell a difference.
    Jeremy Hedges
    #31711
  • Tom D.
    • September 30, 1981
    • 2126
    Re: 67 427 ignition top shield
    Group 9.663 (in a parts book older than 6-79) might show part number 3906150 - 427 distributor cover. I looked it up in order to see what applications were included, but my parts book is not old enough. Even if I found it, the listing may have shown a consolidation of applications. What I mean is the parts book does not always represent a duplication of the applications (or "usages") across the engine options.
    What I can do is check the AIM (Assembly Manual) for 66 and 67 to see if the OEM parts listed are the same.
    Later.
    Tom
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Ralph P.
      • February 1, 1990
      • 253
      The grounding clips rivited to the shield are different.....
