Correct Engine Plugs for 66 427 - NCRS Discussion Boards
  • Christopher A.
    • February 13, 2009
    • 167
    Which plugs in a 66 big block, if any, should be hex fitting/allen plugs, and which should have the exposed square end for a wrench?
    When i bought my car, the engine had unfortunately been messed with by a machine shop and all of the original plugs were gone.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Correct Engine Plugs for 66 427
    all hex. don't recall any allen wrench'd plugs except the ones in the ends of the heads. mike
    • Christopher A.
      • February 13, 2009
      • 167
      Sorry for the confusion in the initial post, exposed hex head or recessed allen head plugs is what i meant to say.
      There are a lot of plugs in the 427 block, are you sure the ones on the front lower portion of the block are exposed hex heads?
      • Michael G.
        • January 1, 1997
        • 1251
        Hex heads are the ticket Chris. No allen head.
        • Christopher A.
          • February 13, 2009
          • 167
          Ok, thanks. Im not in front of the car at the moment, but i think there are 4 on the driver's side, 2 on the passenger, one being for the fuel pump pushrod, and then 2 more on the front of the block, making a total of 8??? Is that correct?
