I had my Q-jet completely went through re color the whole nine yards. Yet I still have starting issues, I have to pump the accelerator to get it to crank. Even if I start it every day I still have to pump it some. The gas where I live is all got about 10% ethanol in it now, could that be the problem? It has all new fuel pump also on it. Seems like someone said that is the way it is now with the fuel we have, that we should get used to having to be pumped and turned over a few times before it will now crank. Is that the experiences of most people with carburetors are now?
Once it cranks, I get a fast idle then the after it warms, the choke works like it should, it is that I just need to pump in order for it to crank. And when I first set the choke it gives it a shot of gas, but it will not crank with out pumping.
