C2 Auto Transmission Brake Pedal Assembly - NCRS Discussion Boards
  • Dennis B.
    • December 1, 2011
    • 92
    Question: Is the brake pedal assembly for an Automatic transmission the same for all midyears? Would there be any identifying marks that would indicate which year the assembly was from?
    Thanks in advance for any help.
    Re: C2 Auto Transmission Brake Pedal Assembly
    Dennis -
    It was the same part from '63-'66, and the part number changed for '67; don't know offhand why.
    • Dennis B.
      • December 1, 2011
      • 92
      Dennis -
      I am looking in the AIM and there appears to be no part number for the entire assembly including the pedal, just the pedal. So I wonder if the pedal changed in 67 and the upper assembly was the same?hmmm3830509 may be the whole assembly?
        Dennis -
        None of that came to the plant as an assembly - it was built up on a subassembly bench from all the detail parts shown in the A.I.M.; the pedal support itself was brand-new for 1967 to accommodate the unique mounting system for the energy-absorbing steering column.
        • Dennis B.
          • December 1, 2011
          • 92
          Thanks, just found out this one came out of a 1964 so I guess it will work, thanks for the help, I appreciate it.
