'64 to mid-65 A/C Compressor Label Stamped Serial Code - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Anybody broken the code yet ? The '65 TIM&JG gives two examples of stamped serial numbers: 92NC1365 and 27NC7989.
    I have two of these early style A6 compressors (but don't know provenance); both have the 8-hole clutch hub; the swaged [not crimped] front case barrel; the '302' cast rear heads; one with I_11_4 and the other J_zz_3 (zz= can't remember the day]. The Sept '64 cast unit has serial 65DC1312 (although the frigidaire label is not the same format as Corvette, might be another GM line); the Oct '63 cast compressor has 85NCx885 [x=can't make it out]. The latter has the same type label as Corvette, and clutch coil connection is even clocked outboard passenger side. Both have the slotted "whistle" relief valve with 440# inscribed.
  • Peter L.
    • May 31, 1983
    • 1930
    Re: '64 to mid-65 A/C Compressor Label Stamped Serial Code
    Wayne - I send you an E-mail via the NCRS DB regards in the 396 fan blade assembly. Did you receive it? Pete
    • Wayne M.
      • March 1, 1980
      • 6414
      Pete -- got it; am checking my data for a response by email right now .
