I have a 69 July 18, build car. The gas cap door when opened has a friction type mechanism that holds it open. In the judging manual it is not suppose to be there. I was wondering if there was a mid year change to a friction holder to hold it open. The unit looked original before I had it re-plated. When was friction holder first used.? Joe
69 gas cap door question
Re: 69 gas cap door question
You are right saying the old JM is incorrect. The new '68/'69 JM will be out later in 2012 correcting this mistake. There was a friction type band/spring to hold the lid up starting with the '68 model year.Terry Buchanan
Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
Corvettes Owned:
1977 Coupe
1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
2003 Electron Blue Coupe
2019 Torch Red Grand Sport Coupe- Top
Joe-----I have a 69 July 18, build car. The gas cap door when opened has a friction type mechanism that holds it open. In the judging manual it is not suppose to be there. I was wondering if there was a mid year change to a friction holder to hold it open. The unit looked original before I had it re-plated. When was friction holder first used.? Joe
I don't understand what you mean by a "friction type mechanism". ALL 1969 Corvettes originally had a gas door bezel with a "riveted" spring clip on the underside of the hinge extension. When the door was fully opened, the hinge snapped into the spring clip holding the door open. The door had to be pulled with some force to disengage it from the spring clip. The clip often broke off from the bezel's integral "rivets".In Appreciation of John Hinckley- Top
Terry,
Thanks for the reply, thats great news that the TB is being corrected. I will be glad to have another point. Every little bit helps.
Joe, technical you are correct, but as you pointed out the spring clip provides friction that holds it place. Thanks for the info on the door. I will take it easy with the door.- Top
Terry,
Joe------
I would not describe the mechanism involved here as friction-based. The clip simply provides a mechanically-based retention of the hinge.In Appreciation of John Hinckley- Top
