I have a few original 3779185 Idler arms and noticed a slight difference
in the arm configuration..... two have a straight arm and two have a curve in the arm. is there any reference to years of application of each? also I have a slight difference in the tie rod end clamps. It's hard to tell in the photos but 4 have a smaller more defined raised rib and the others have a more rounded rib. are any of these original to the period ? note the last clamp has a flat section where the hole is for the bolt to pass through.
