Heater Hose Fitting on Water Pump for 67 435 - NCRS Discussion Boards
  • Mark D.
    • June 30, 1988
    • 2142
    Any opinions on if it should or should not have 'notches' on the hex portion or be smooth? If it should have notches, how many should it have, one, two or three?
    If anyone isn't comfortable answering on the TDB, my email is Mdonnally@aol.com and my number is 859-612-9121.
    Mark
    Kramden
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Heater Hose Fitting on Water Pump for 67 435
    Mark, there were three of these that I know of, no notches, one notch & two notches and for each version one thousand opinions each.
    Here is where I am at with this. This was Engine Plant installed, given that and engine plant made thousands of engines a day, it is possible that Flint had one supplier and Tonawanda another. So it would seem to be very improbable that in a given year you'd have all three styles on one engine version. On the survivor photos I have from Novi for example the 67 327 had no notches, maybe one on the 66 BB but the others would appear to my eyes as being massaged.
    • Rick G.
      • March 1, 1983
      • 270
      Hi Mark,
      My May1967 built 435/427 does not have any notches. I am the second owner and have known the car since the early 1970's and believe the fitting to be original to the car.
      Rick Gower
      • Mark D.
        • June 30, 1988
        • 2142
        Thanx Rick
        Mark
        Kramden
        • Mark D.
          • June 30, 1988
          • 2142
          Thanx Ron
          Mark
          Kramden
            • 15573
            Thanx Rick
            Mark
            Thanx Ron
            Mark
            Thanks Mark!
            • Mark D.
              • June 30, 1988
              • 2142
              Wisenhiemer
              I thought you said you had a job.
              Kramden
                • 15573
                Yep, my job is tweaking you.
                At least I don't text while flying, or driveing. in fact i don't text at all.
                  Originally posted by Ronald Lovelace (50931)
                  Here is where I am at with this. This was Engine Plant installed..
                  Ron -
                  The heater hose return fitting on the water pump was installed at St. Louis; only the bypass hose fittings were installed at the engine plants.
