20120201_213608.jpg20120201_213716.jpgcar. Is this a big deduction from the judges? The other 58-60 cars have their molding riding the edge of the wheel well.
Look closely
Re: Look closely
Hi Al
Thats why i choose a Snowcrest White
- Top
Re: Look closely
Al,
Mine is closer to the wheel opening then yours. It was probably not an exact science in 1960 when it came to mounting these moldings.
I seem to recall a thread a while back discussing where the cove painting started and ended. For some reason I don't recall it extending along the fender lip as yours shows. It might be worth soem time spent in the archives. Plus I'm sure someone else will chime in here. My coves are body color so I'm no help...........
Tom1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
Re: Look closely
My 59 had body work done on both front fenders by a previous owner and myself. The moldings had been removed and the holes filled when I got it. Because of the body work I had to drill several new mounting holes on the left side and all of the holes on the right side. The cove molding on the left side fits pretty close. I played around with the holes on the right side to get th molding as close to perfect as possible, evan bending the molding slighly. The molding is still off by about 1/2 inch on the right side.
I looked at every photo that I could find and there are a few 58-61's that have the cove molding off a bit. Refering to the book that was discussed recently,"The Complete Book Of Corvette" By The Auto Editors of Consumer Guide, look at the 58 on page 87.- Top
Re: Look closely
There was a time ('90s/early 2000s?) when one of the reproduction suppliers of these pieces apparently had ABSOLUTELY no idea of quality control. We had to order the RF long piece 4 times; one was 1 1/2" short; another was 2" too long; a 3rd had three dents in the surface on arrival; the 4th was not bent correctly but had to be used to meet a show schedule.- Top
Re: Look closely
Well.. these have never been replaced. The previous owner in 1978 had the car repainted at the GM body shop to clean up some cracked paint. I do not see where they drilled new holes in the fender. From under the fender there are NO additional holes on either side. So I would assume these are able to slide back and forth to get the correct fit. If not somethin' ant right from the factory. I just want it to be factory correct.- Top
Re: Look closely
I have a 60 currently being painted by a guy who has been doing strickly vette body/paint for 35 year and he also said the cove color (white in this case) stops at near the top center of the wheel well. Al, from you first picture, looks like whoever painted it back when recognized that the molding didn't fit right so they continued the cove color all the way around the wheel well. We had to replace the front end on my 60, and had a hard time getting the molding to follow the edge of the wheel wells, but by adjusting and a little bending we were able to get them pretty tight. Depending on your paint line, you may be able to adjust some by elongating the mounting holes.Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Re: Look closely
Don,
I too have seen it where it stops in the center of the wheel well. However, you are correct. This guy did realize that it was not a clean fit. So i will just assume that this is factory. Since no other holes exist, just wonder how was it painted at the factory. I will try your suggestion and move it around to see if it will hug the edge of the well.
Thanks everyone!!- Top
Re: Look closely
You don't need NEW holes to replace mouldings; if your car was so untouched after 18 years that the side fender stainless did not have dents and bends, you are fortunate indeed - especially when all of these pieces could be replaced at a list price of $50/60; if NEW mouldings that are improperly bent are put into original holes, they are not going to fit correctly.
