69 Carpet with or without jute - NCRS Discussion Boards
  • Paul K.
    • February 1, 2002
    • 160
    When ordering carpeting for a judged 69 vette, do i order with or without jute,
    what underlayment do you recommend
    Paul klemetson
    • 3415
    Re: 69 Carpet with or without jute
    Hi Paul,
    Here are a couple of pictures of the padding from my 71. I believe the padding used on your 69 is similar
    I don't think anyone is making anything very close to it these days.
    Hopefully this will give you some idea of what to look for.
    Any chance you can reuse your original pads?
    This padding was hit and miss glued to the carpet.
    Rear wheel housing
    Seat bulkhead
    This padding was loose from the carpet and had a dense (rubber ?) coating on the carpet side of the padding
      • 15573
      Nice pictures Alan. Those are some of the best carpet photos I have seen.
        • 3415
        Hi Terry,
        Thanks!
        Fortunately I was able to reuse everything but the 2 front carpet pieces.
        • Lyndon S.
          • April 30, 1988
          • 1027
            • 15573
            Hi Terry,
            Thanks!
            Alan, I see you have those foam corner blocks in your coupe. Me too.
            • Ron G.
              • December 1, 1984
              • 865
              FYI - 1971 Coupe #4504 also had it's foam corner blocks.
              "SOLID LIFTERS MATTER"
                • 3415
                Hi,
                FYI - 1971 Coupe #6589 had only ONE foam corner block.
                It grew another during restoration, to please my sense of symmetry!
                • Floyd B.
                  • November 1, 2002
                  • 1046
                  But as a matter of judging; are the judges really going to be able to tell what kind of padding is under the carpet?
                  "Drive it like you stole it"
                  • Reba W.
                    • 932
                    Yes, we judges can usually see some jute and padding at the cut for seat tracks and behind the seats.
                      • 3415
                      Hi Floyd,
                      I've also seen signs of the jute pad at the top of the rear bulkhead carpet. I think whether you see it or not depends on how carefully the padding was placed relative to the carpet.
