Midyear vent window removal from vent assembly - NCRS Discussion Boards
  • Dale M.
    • December 27, 2007
    • 386
    I must be missisng something. Can anyone guide me to the technique to remove the door vent window from the vent window assembly. I have the assembly out of the car. Thanks for any help.
    Shop manual states "Push down on window to disengage upper pivot pin from frame" Do I need to remove some of the rubber weather stripping to get it down far enough to get the top pivot post out?
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Midyear vent window removal from vent assembly
    The glass is held in place by the rubber friction (unless someone used cement as a repair). I was able to SLOWLY work the glass out by pulling on the glass and the top of the frame. Once you get it started it becomes easier to remove. You may try to hold the glass and using a block of wood against the end of the frame top, tap the block with a mallet to loosen the frame. That would be easier with 2 people.
    Good luck
    I just read your edit... are you trying to get the glass out of the frame, or the frame off of the complete assy?
    • Dale M.
      • December 27, 2007
      • 386
      Thanks, I am trying to get the window frame and glass out of the complete assembly. Sorry, it get hard to explain. I am replacing the weatherstriping around the vent windows.
      • Michael G.
        • January 1, 1997
        • 1251
        Been there done that Dale. Your not pushing down hard enough. The rubber w/s will offer resistance, you'll need to supply the pressure pushing down in order for the "pin" to clear the frame.
        • Dale M.
          • December 27, 2007
          • 386
          Michael, Thanks, my first time and I did not want to bend anything. I guess my robber is old (original) and very hard. Since I am replacing the rubber, I may cut some of it down to make it easier. Now I will know.
          • Joe R.
            • July 31, 1976
            • 4547
            Dale,
            You do have to remove the vent window regulator from the shaft and then push down hard on the vent window frame.
            JR
            • Dale M.
              • December 27, 2007
              • 386
              I will be working on it this evening. I do have the regulator removed as it is broke. I just need to use more force pushind doen on the vent window frame and it should come out OK. Thanks for you input and time to reply to my post. Dale
              • Michael G.
                • January 1, 1997
                • 1251
                No problem Dale. Let us know how it goes.
                • Al R.
                  • June 30, 1988
                  • 687
                  Anybody know where one could purchase just the ss frame that holds the glass ( passenger side convertible 67 )
                  • Dale M.
                    • December 27, 2007
                    • 386
                    Thank you everyone for your replies. I was just my first time and I did not apply sufficient pressure and with my old rubber being so hard, it was difficult getting the vent window our of the assembly. I finally just removed some of the old rubber and poped it out. Thanks, Now I know.
