Looking for a clutch / flywheel combination for 1964 L76 - NCRS Discussion Boards
  • Geoff B.
    • March 18, 2008
    • 35
    I found other threads that recommended the LUK 04-021 clutch for the L-76. Is there a flywheel that works best with this clutch? I found the GM Performance 14085720 on Summit's site. http://www.summitracing.com/parts/NAL-14085720/
    Is it better to stick with a LUK flywheel or are there other recommendations?
    Re: Looking for a clutch / flywheel combination for 1964 L76
    Geoff------
    The GM #14085720 is a lightweight flywheel. It's a good replacement for 1965 L-78 which originally used a lightweight flywheel. However, for a small block I'd go with a standard weight flywheel as all C2 originally used. If LUK has one available, I'd go with it.
