New to vettes.
Just bought 61 w/ 2x4's and was told it is correct 283 w/ 270 hp but I want to verify and document How can tell if I have solid lifters vs. hydraulic by looking ? do I have to pull intake or is there a simple way to determine. Is there a difference under the valve covers that will tell. By the way, I have pulled off the oil pan to fix leak and do see green stripe cam ( for those who remember the terminology of green vs pink stripes) . Is that cam correct for 283 w/ 2x4's and 270 hp?? Also the block is stamped CU. Is that correct? thanks for the help, Mike 53700
